hell experts .. i have a problem i m using mikrotik with vmware.. i want to use pptp client in mikrotik and merge it to the host.. i did the following check and suggest me a solution.. thanks
What is the issue? Is traffic not being forwarded? What are you trying to do?
I can see from the images that your device is able to connect to the PPTP server and its network is reachable.
I am attempting to set up a PPTP server myself, at the moment, but for some reason it won’t forward traffic. I just have to find the config error on my BSD box!
thanks for reply.. exactly the pptp client traffic is not forwarded .. when i connect through ppoe without the pptp client it works but when pptp client connects. then not working…
What traffic? Do you have a route on both ends or are you trying to use the same subnet on your LAN and VPN?
Post /export compact for both of your routers.
sorry i m not an expert.. simply i install mikrotik on vmware in my personal pc.. i setup ppoe connection and when i dial i connect through the internet with mikrotik.. now i want to setup a vpn inside mikrotik and use it in my pc..
