First of all I apologize for my bad English. I want to do pptp client load balance i did it once before but i don’t have it anymore and I tried it myself once but can’t remember how I did it. Someone will guide?
And thanks in advance for taking the time to read my post and reply in return
Not sure what you mean?
If you mean run a server on your router for other users maybe you want queues??
You can distribute traffic among multiple tunnel interfaces exactly the same way like you would distribute it among multiple WANs, and there are tens, if not hundreds, topics dealing with such a task here on the forum.
An important question is whether all the PPTP clients will connect to the same PPTP server or whether each of them will connect to its “own” server, because in the “common server” case, you may get slightly better results if you can configure also the server.
Is it correct to assume that you want each PPTP client to use another WAN?
And last, why would you use PPTP if L2TP is equally simple to set up but can pass through NAT much better and provides more security?
As for English, diagrams are an international language, and a photo of a drawing made by hand is perfectly fine to convey the idea.
