PPTP client not getting correct local IP
I have a Mikrotik running as a PPTP client, connecting to a Cyberoam PPTP server. The PPTP client is showing an IP from a range not available on the Cyberoam server, and this IP remains the PPTP Local IP even when setting up and connecting to other PPTP servers. Removing the address from IP addresses does not prevent the PPTP client “receiving” the incorrect IP. Is there any way to clear this incorrect address?
Thanks,
Patrick
I would suggest looking at the default profiles for your PPP connections.
By default the PPTP client connection will use the “default-encryption” profile.
You can use the following command or just go to PPP > Profiles
/ppp profile print
