pptp client over pppoe connection
hello
i have a mikrotik router with pppoe-client connection and i have a ppptp-client account i want to make it connect through pppoe connection and all traffic should pass through the vpn conneciton .. i connect the pppoe client first and when i connect the vpn client it connects but no traffic passes because i found in ip route the default route of pppoe client is inactive , how can i pass all traffic through vpn ?
regards
do not use “add default route” in pppoe-client
add a static route to your vpn server
ip route
add dst-address=vpn-server-ip gateway=pppoe-gateway
in pptp-client configuration use “add default route”
wow , great idea
thanks you it works fine
