PPTP-Client Problem on Mikrotik x86
Hai there,
I have some problem with mikrotik routerOS x86.
Recently i already installed RouterOS 6.35.4 in our brand new server.
All things work except the PPTP-Client.
Before this, our office use mikrotik x86 on VMWare Host, and PPTP-Client connect and working.
I try to backup and restore config file from the old and working router to our new router, but no luck there.
I already try with different tunnel, L2TP and SSTP working as expected.
At PPTP-Client status, stuck on “Link Established”
This is the log from my router ( PPTP-Client - Non Working Router )
18:23:32 pptp,ppp,debug pptp-out1: LCP lowerdown
18:23:32 pptp,ppp,info pptp-out1: terminating...
18:23:32 pptp,ppp,debug pptp-out1: LCP down event in starting state
18:23:32 pptp,ppp,info pptp-out1: disabled
18:23:32 system,info device changed by admin
18:23:34 pptp,ppp,info pptp-out1: initializing...
18:23:34 pptp,ppp,info pptp-out1: connecting...
18:23:34 system,info device changed by admin
18:23:34 pptp,debug,packet sent Start-Control-Connection-Request to xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet     protocol-version=0x0100
18:23:34 pptp,debug,packet     framing-capabilities=2
18:23:34 pptp,debug,packet     bearer-capabilities=0
18:23:34 pptp,debug,packet     maximum-channels=0
18:23:34 pptp,debug,packet     firmware-revision=1
18:23:34 pptp,debug,packet     host-name=MikroTik
18:23:34 pptp,debug,packet     vendor-name=MikroTik
18:23:34 pptp,debug,packet rcvd Start-Control-Connection-Reply from xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet     result-code=1
18:23:34 pptp,debug,packet     error-code=0
18:23:34 pptp,debug,packet     host-name=Kudoplex Router
18:23:34 pptp,debug,packet sent Outgoing-Call-Request to xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet     call-id=0
18:23:34 pptp,debug,packet     call-serial-number=0
18:23:34 pptp,debug,packet     minimum-bps=2400
18:23:34 pptp,debug,packet     maximum-bps=10000000
18:23:34 pptp,debug,packet     bearer-type=3
18:23:34 pptp,debug,packet     framing-type=2
18:23:34 pptp,debug,packet     packet-recv-window-size=100
18:23:34 pptp,debug,packet     packet-processing-delay=0
18:23:34 pptp,debug,packet     phone-number-length=0
18:23:34 pptp,debug,packet     phone-number=
18:23:34 pptp,debug,packet     subaddress=
18:23:34 pptp,debug,packet rcvd Outgoing-Call-Reply from xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet     call-id=1
18:23:34 pptp,debug,packet     peers-call-id=0
18:23:34 pptp,debug,packet     cause-code=0
18:23:34 pptp,debug,packet     connect-speed=100000
18:23:34 pptp,debug,packet     physical-channel-id=0
18:23:34 pptp,ppp,debug pptp-out1: LCP lowerup
18:23:34 pptp,ppp,debug,packet  pptp-out1: sent  pptp-out1: sent  pptp-out1: sent  pptp-out1: sent  pptp-out1: sent  pptp-out1: sent LCP ConfReq id=0x1b
18:23:34 pptp,ppp,debug,packet    <mru 1460>
18:23:34 pptp,ppp,debug,packet    <magic 0xbb317e4>
18:23:34 pptp,ppp,debug,packet    <mrru 1600>
18:23:34 pptp,ppp,debug pptp-out1: LCP open
And this is the log from PPTP-Server
18:23:34 pptp,info TCP connection established from xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet rcvd Start-Control-Connection-Request from xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet sent Start-Control-Connection-Reply to xxx.xxx.xxx.xxx
18:23:34 pptp,debug,packet rcvd Outgoing-Call-Request from xxx.xxx.xxx.xxx
18:23:34 pptp,ppp,debug <1>: LCP lowerup
18:23:34 pptp,ppp,debug <1>: LCP open
18:23:34 pptp,debug,packet sent Outgoing-Call-Reply to xxx.xxx.xxx.xxx
18:23:34 pptp,ppp,debug,packet  <1>: rcvd LCP ConfReq id=0x1b
18:23:34 pptp,ppp,debug,packet  <1>: sent LCP ConfReq id=0x1
18:23:34 pptp,ppp,debug,packet    <magic 0x25ce98d4>
18:23:34 pptp,ppp,debug,packet    <auth  mschap2>
18:23:34 pptp,ppp,debug,packet  <1>: sent LCP ConfRej id=0x1b
18:23:35 pptp,ppp,debug <1>: LCP timer
18:23:35 pptp,ppp,debug,packet  <1>: sent LCP ConfReq id=0x2
18:23:35 pptp,ppp,debug,packet    <mru 1460>
18:23:35 pptp,ppp,debug,packet    <magic 0x25ce98d4>
18:23:35 pptp,ppp,debug,packet    <auth  mschap2>
18:23:37 pptp,ppp,debug <1>: LCP timer
18:23:37 pptp,ppp,debug,packet  <1>: sent LCP ConfReq id=0x3
18:23:37 pptp,ppp,debug,packet    <mru 1460>
18:23:37 pptp,ppp,debug,packet    <magic 0x25ce98d4>
18:23:37 pptp,ppp,debug,packet    <auth  mschap2>
18:23:39 pptp,ppp,debug <1>: LCP timer
18:23:39 pptp,ppp,debug,packet  <1>: sent LCP ConfReq id=0x4
18:23:39 pptp,ppp,debug,packet    <mru 1460>
18:23:39 pptp,ppp,debug,packet    <magic 0x25ce98d4>
18:23:39 pptp,ppp,debug,packet    <auth  mschap2>
18:23:41 system,info,account user admin logged in from xxx.xxx.xxx.xxx via telnet
18:23:43 pptp,ppp,debug <1>: LCP timer
18:23:43 pptp,ppp,debug,packet  <1>: sent LCP ConfReq id=0x5
18:23:43 pptp,ppp,debug,packet    <mru 1460>
18:23:43 pptp,ppp,debug,packet    <magic 0x25ce98d4>
18:23:43 pptp,ppp,debug,packet    <auth  mschap2>
Any help would be appreciate.
And i’m sorry for my bad english.
the problem is Windows related.
Many of my PPTP-servers suddendly (probably all) stop to work with Windows client.
I suppose it’s related with something changed during a Windows Update.
I’m still investigating the problem, anyway the problem is not related to your RouterOS update.
Massimo
Haii thank you for your reply.
Unfortunately, my setup is mikrotik to mikrotik.
I already try connecting from windows to current mikrotik PPTP Server, and everything working as expected.
Sent from my Mi 4i using Tapatalk
