PPTP Client to bridge
I need to achieve something on Mikrotik which I can’t figure out myself.
Basically I have typical configuration.
  1. Static IP and FEED IN connected to ETH1
  2. DHCP Server on Bridge1 with Eth2, Eth3
  3. Gateway inside route list
# DST-ADDRESS        PREF-SRC        GATEWAY            DISTANCE
0 A S  0.0.0.0/0                          XXX.XXX.XX.162            1
  1. masquerade on ETH1
Now I connected the router to PPTP server using the PPTP Client.
I am connecting with no issue
status: connected
uptime: 27m20s
encoding:
mtu: 1610
mru: 1600
local-address: 10.0.2.202
remote-address: 10.0.2.32
I wish to somehow make this PPTP Client connection available either on ETH4 or on the BRIDGE2 so If I plug something to ETH4 it will be going through that PPTP and essentially have access to local resources on PPTP Server.
So If I plug something to ETH2 I get access to local resources on Mikrotik but if I connect to ETH4 I will get access to local resources on the remote router.
I hope I explained the query clear enough.
This could possibly be solved by just routing over the PPTP connection to the far end resources. Say your PPTP subnet is 10.10.10.0/24, you would add this:
/ip route add dst-address=10.10.10.0/24 gateway=10.0.2.32 (or could possibly use interface name if you create a binding for it).
Depending on whether or not you need to have the reverse happen (PPTP server subnet route back to Local LAN) you could add a src-nat masquerade rule to the PPTP client connection.
This would then just be saying basically, anything destined for 10.10.10.0/24 send it over the PPTP connection with a src-address of 10.0.2.202 (Your clients PPTP ip address).
Hope this helps.
