PPTP CLient to MS PPTP Server Problems
Can anyone give me a pointer to hook up the PPTP client to a MS Windows PPTP Server i can’t even seem to get the client to get a connection to the server.
First check if you have 47 IP protocol (GRE) and 1723 TCP port enabled between the client and the server, then check the logs.
