PPTP Client
hi
i crate vpn connection as shown in the picture
the vpn is connected
But still all devices connect to the Internet without vpn
plz help :open_mouth:
MikroTik RouterOS 4.11
Try using the firewall to filter the unwanted traffic from accessing the internet.
I’m assuming you’re trying to stop clients from accessing the WAN unless their IP is in the 192.168.111.0/24 subnet.
So block all traffic that is not 192.168.111.0/24 from going out the WAN.
I’m going off assumptions here cause you didn’t really provide any information in your original post as to what you’re trying to accomplish.
Thank wildbill442
I tried , Did not work
Image to make sure the connection vpn is works but no data is transferred
I checked this page did not work any way
http://www.mikrotik.com/testdocs/ros/3.0/vpn/pptp.php
what routes you have, you have to tell traffic to go through tunnel.
hi janisk
tell me how i can tell traffic to go through tunnel
