PPTP connection bundling
Hi guys,
where I live they like to limit your speeds - and they even do it on VPN connections - so max transfer tops out at maybe 1200-1400 kbps no matter what I do but when I use “non-std” multiple UDP stream transfer software is able to reach close to full bandwidth. (on 16mb i can get about 12 mb in transfer speed.)
So if I had MT in both ends - could I bundle 2 VPN connections (maybe to seperate dest IPs - both both dest IPs on same MT router?)
That feature would kick :slight_smile: a**
the simpliest solution is load-balancing http://wiki.mikrotik.com/wiki/PCC#Application_Example_-_Load_Balancing
but if you have RouterOS on both ends - you may try to use bonding, http://wiki.mikrotik.com/wiki/Bonding
thanks - will bonding work over x number of PPTP links? Load balance will not work since im trying to increase speed on 1 stream and thereby work around the ISPs limits- not multiple streams.
has anyone tried? or have a short get started guide? :slight_smile:
I have a MT on a ESXi as the “vpn” server and have a few RB750 and RB450G which I would like to bond.
best
Kasper
yes, it will work, but all links should have same speed
okay im trying to figure out how to set it up.
I have now both PPTP and OVPN enabled as servers.
questions: Since I cant use dynamic IPs on the interfaces - and the interfaces need to be created “up front” how is the best way to set it up?
/bonding only accepts a valid interface name. You don’t get that on a dial-up?
any help would be appreciated! :slight_smile:
best
Kasper
create pptp-servers for necessary login names
so do i create 2 x vpn login servers on destination - and then 2 x vpn client “devices” on remote host?
I have seen I can set a username - but no password. Will password come from the Secrets?
yes. if client with that username connects to your server, this interface brings up and serves that client (i.e. new dynamic interface is not created)
thanks for your help. I got it to work - but it was not a happy trial :slight_smile:
combined speed was lower - and that seems to be due to available bandwidth jumping up and down on each interface due to ISPs “network management”
So next trial is a UDP based tunnel :slight_smile:
thanks!
so, did you use bonding? in what mode? RR is not the best for non-ideal links %)
i tried RR - but that was not good.
what would you recommend? I have tried multi channel UDP streaming with file transfer software - and I can actually get about 6+ mpbs constant traffic from my server to here. But using VPN i max out on 700-800 kbps via MT on same network. When I used bonding - interfaces jumped up and down in speed. I tried both L2TP and PPTP vpn with more or less same results.
best regards
try ALB or XOR mode
Hi there been reading this with some interest.
I have been using bonding with MT for some time now, but this has always been simple and the main route is over the two ISP connections.
I have in the past set up connections for customers and have give them a public IP from our Data centre pool and routed there traffic this way so they do not see we are using a third party ISP in some locations.
What i now want to do is tunnel the customer traffic back to our data centre router, but using a bonded method to give faster connections and a public static IP from our data centre core, we have used sharedband in the past which works, but im pretty sure we can do this over microtik.
I have icore 36 in the dc so this will serve as the pptp agregation server.
I think i need to setup the bonding as normal
WAN1
WAN2
Then Create
VPN1
VPN2
Mangel rule
mark packets from x IP mark as VPN1 and VPN2
Create route rule 0.0.0.0/0 from all traffic marked VPN1 or VPN 2
Then all traffic will be split across the two tunnels to the core router in the DC working as a aggregation point.
Can you see anything wrong with this? or a better way
Adrian
