PPTP connection crushes
Hi!
My name is Miro and first of all, sorry on my bad English!
My problem is PPTP connection and large ammount of data over PPTP. So, I have one RB333 and several PPTP conection over ADSL. When I sent a few MB every PPTP connection on my RB333 going down. I try with dynamic queue and I saw some progress but not too much! I try with firewal mangle and it is same.
Maybe someone know how I can do this correctly?
Thanks in advance!
Miro
hi. how you can do what correctly?
Hi!
Corectly configure PPTP or queue!
what queues do you want to apply?..
Hi again!
I am looking for way to solve my problem and my problem is crushing PPTP connection when I try to copy large amount data over it.
In present I set max speed and I create simple queue. The situation is beter now but not too much better.
What I can try? Maybe some correction in configuration, maybe I need configure queue but I dont know how, maybe some other way, I dont know!
If someone know please reply to this post!
TNX!
Miro
does your pptp disconnect even without any queues? did you try to set queue type for your interfaces to, say, SFQ or something?
Yes, disconnect with and without queues.
Every time I start copy a little bit large file RB or something crushes all pptp connection!
what version do you use? what is shown in Log?
What You need to see and how I can get (I am new with mikrotik) and last my mail is: m.burazer@vip.hr
If You can send me Your mail address to send You log or something.
I am desperated becouse I need some solution!
what version do you use? is there any messages in log when pptp crashes?
