PPTP connection from remote WAN to LAN
I am trying to setup PPTP Server on MT 2.9.46. There is no problem to connect from windows xp vpn client to MiktoTik. But i can’t reach any other host in LAN. For instance, i can ping 192.168.1.1 - MikroTik LAN port addresse, but i can’t ping 192.168.1.2 - linux server. I have the same address pool that LAN hosts, firewall is disabled.
Does Linux server has a route to reach the pptp clients.
YES, MikroTik addresse is gatway at linux machine.
If you can get the PPTP up but client can’t ping or connect anything behind the MT. Please make sure you change the ARP setting in your LAN interface from enable to proxy-arp.
