PPTP disconnect after 1 min. 33 sec.
Hi, I’m a MT newbie. I have two MT routers connected with each other through PPTP. The connection disconnects after exactly 1 min 33sec. The log shows “terminating.. peer is not responding” After a while, the connection reestablishes itself and disconnects again after 1:33. This scenario goes on and on like this. Anyone experienced a similar problem? Any help would be appreciated. Thanks.
something is blocking ppp keepalives?
is there a workaround that I can do if something is blocking PPP keepalives?
