pptp get connect-to ?
I am currently trying to make simple script for load balancing on a few of my MKTs and the key point of the whole script is getting the address a pptp-client connects to. If I am not mistaken, the command should be : [/interface pptp-client get $vpninterface connect-to]
The problem is, it simply does not get any address and doesn’t return any value. I have about two dozen routers on different firmware and not one of them seems to work with that command.
Here is a part of my script :
:local stara “31.45.237.250”
:local nova “31.45.237.254”
:local “trenutna” [/interface pptp-client get $“pptp-racunala” connect-to]
:if ( [/interface pptp-client get $int running] != true ) do={
:if ($“trenutna” = $“nova”) do={ /interface pptp-client set pptp-racunala connect-to=$“stara”}
The bold part is giving me a hard time, so I would really appreciate any information on my mistake or if you can provide me with any insight on a workaround.
Regards
Našel sem veliko napak.
Z pptp-ime statična =“pptp-racunala”:
:local stara value="31.45.237.250";
:local nova value="31.45.237.254";
:local trenutna value=[/interface pptp-client get pptp-racunala value-name=connect-to]
:if ([/interface pptp-client get pptp-racunala value-name=running] = false) do={
 :if ($trenutna = $nova) do={ /interface pptp-client set pptp-racunala connect-to=$stara }
Z pptp-ime dinamično:
:local pptpime value="pptp-racunala"
:local trenutna value=[/interface pptp-client get $pptpime value-name=connect-to]
:if ([/interface pptp-client get $pptpime value-name=running] = false) do={
 :if ($trenutna = $nova) do={ /interface pptp-client set $pptpime connect-to=$stara }
Translation to English:
:local pptpname value="pptp-computer"
:local old value="31.45.237.250";
:local new value="31.45.237.254";
:local current value=[/interface pptp-client get $pptpname value-name=connect-to]
:if ([/interface pptp-client get $pptpname value-name=running] = false) do={
 :if ($current = $new) do={ /interface pptp-client set $pptpname connect-to=$old }
Če sem ti pomagal, dodajte Karma,
Hvala.
