PPTP hangs after 100MB
Hello!
The problem is that PPTP connection on RB532 hangs when sent a bit more than 100MB smb or ftp data. After hangup, data transmitting just stops (but no disconnects or connection errors occur). Ping after hangup is alive both ways.
There are no limits set for PPTP user.
RouterOS version: 3.23
RB532
Tried tunneling to RB from various places, Windows 2000, Linux Fedora.
Advices?
Thank You!
try to add one simple queue with max-limit 100M (any interface, any other settings) and see if problem continues.
Seems like this helped :slight_smile:
Thank You!
What was the cause?
Normis?.. =)
No idea, still looking, but it seems that it helps :slight_smile:
bump
