I am using EoIP to connect two locations together and that connection is working fine. I can ping poing A from point B and point b from point a.
I have people that pptp into point A and they can reach everything at point A but it can not reach anything at point B. It wont even ping the LAN ip of the router at point B. Also the point B router can not ping the ip address assigned to the pptp connection but the router at point A can.
Summary: EoIP works fine, pptp works fine but once clients connect into the router with pptp they cannot move across the EoIP connection.
I do not believe that is the problem because the addresses assigned to location B are in the middle of the sub-net at 160 but i can ping things on either side of that IP at location A. so i can ping .254 as well as .5.
