i setup an rb951 in most simple config just to access the webfig via vpn and tried 2 different ones (pptp and l2tp). Both are running but i have no ping to public adresses (even 2 different gateways!)
I guess the fault is in the config…
[admin@MikroTik] > export compact
# jan/04/1970 12:07:58 by RouterOS 5.20
# software id = LD1K-MDA1
add l2mtu=1598 name=bridge1
/interface l2tp-client
add connect-to=vpnserver1 disabled=no name=l2tp-out1 password=xxxx user=\
xxxx
/interface pptp-client
add connect-to=vpnserver2 disabled=no name=pptp-out1 password=\
xxxx user=xxxxx
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address=192.168.0.41/24 interface=bridge1
add action=dst-nat chain=dstnat dst-address=vpnip1 to-addresses=\
192.168.0.41
add action=dst-nat chain=dstnat dst-address=vpnip2 to-addresses=\
192.168.0.41
add check-gateway=ping distance=1 gateway=192.168.0.254
/system routerboard settings
set cpu-frequency=400MHz
[admin@MikroTik] >
