Hi
I have problem to set up PPTP too VPN service.
VPN-service
I dont have controle over VPN service.
(it works when setting up a PPTP-client in winXP/Vista to this VPN service)
I connect to:
IP: DNS name, ip address could be different every time.
ex 1.1.1.1
I have two interfaces
Router
- Outside interface–>DHCP
- Inside 192.168.1.0/24
Client
- windows xp client on the inside, -->DHCP from Router.
Configuration
- I configured inside interface with static IP
- outside interface using DHCP wich doesnt create any default route.
- Src NAT, with WAN as outside and using action masquerade.
- winXP client can now reach Internet from inside.
Now starting with PPTP configuration
4. Static route to VPN-service(were tunnel is terminated).
5. Configure PPTP-client.
- it connects to the VPN service -->status connected
- Change Src NAT to use PPTP-interface as outside
- Client has no internet access
8 In routing-tabel I got a default route pointing at VPN-service 1.1.1.1 through the tunnel
90 seconds it seems that the tunnel reconnects, the status is always connected but I can see that the routes to the tunnel dissapear
No firewall rules exist (Only NAT)
Is there something more I must Add or change
Cheers
Liam
