when i try to delete or disable a PPTP client connection on the router, the router reboots. This is also true if you disable the PPTP Server.
Also, when an L2TP client gets disconnected, the dynamic IP Address does not get deleted.
Any fixes?
Any fixes?
send a supout to support@mikrotik.com
