I´m trying to connect with a same user, and simply, not authenticate.
The user exist, the password its ok.
The ppt server is enabled. And works fine on 2.9.23
Any suggestion?
rgs,
Fernando
Any suggestion?
rgs,
Fernando
Can anybody give an idea pls? ![]()
I have upgrate to .24 and PPTP server has not problem until now
try to remove the user and recreate it . sometime it works
Nice try. All ready done. No success.
The problem is tha do not recognice user and password.
I don´t know why.
On 23 version, works fine.
Deleted user and recreated, and not work.
Thx, for your time
Fernando
SOLVED, if you use service pptp, does noçt validate user, if you use any as service, works fine.
THX for your effort.
Fernando
