Hello, I’m having trouble using PPTP over PPPoE. My version is 6.43.2 [stable]
When I dial to use default route, mikrotik creates an automatic route to the IP of the PPtP server, with the server’s own IP gateway. In this case, this route has unreachable status.
I’d say help with understanding the philosophy. If you set up any kind of tunnel connection over any other kind of connection and want the tunnel to become a default route, you have to create an exception for the tunnel packets themselves, towards the destination of the tunnel. So the distance parameter of the default route via PPTP must have a lower value than the one of the default route via PPPoE, and there must be a /32 route to the PPTP server via PPPoE. A route with more precise match (longer mask of dst-address) always wins over all routes with a less precise match (shorter mask of dst-address), so even while the PPTP is up, its transport packets will continue to be sent via PPPoE.
525/5000
Sorry.
The problem would be that when PPtP creates the routes dynamically and the communication with the internet is through PPPoE, an incorrect route is created for the IP of the PPtP server. So communication through PPtP does not happen. It is as if the PPtP client did not find a connection to assign this dynamic route to the PPtP server IP.
The static route to the IP of the PPtP server was added in the routing table to work around the problem. But before performing the upgrade, it was not necessary due to the fact that there is no such problem.
Below is the print of the routing table in version 6.39.2 [stable] of an RB, which is working correctly.
