pptp over pptp
Hello
I have q i need make some conections situation is like that
PC ============= (pptp over internet got address from RB951 172.17.17.200 )=============>RB951HND (WAN x.y.z.c , LAN 172.17.17.1/24)
pptp over internet and got address 192.168.5.200 from pptp server on 2011
RB2011 (wan x,y.z.a, lan 192.168.5.1/24)
My pc conect over pptp to 951 and 951 had pptp conection to rb2011 how to make my pc had accest to network 192.168.5.1/24
all pptp work fine when i conect to 2011 had full access to 192.168.5.0/24 same with 951 had access to 172.17.17.0/24
Hi
It’s just a question of your pc knowing how to reach the .5. network.
Is PPTP to 951 taking over all traffic? So is 951 becoming the default gw/route?
If so: then no need to change anything at pc
If no: you’ll need to add routing entry for .5. to go over the link to 951
Similar story at 951: does it know how to route to .5. ? If not you’ll need to tell it that it should go over pptp.
