PPTP Passthrough
hello all
i have a mt router doing Nat masqurading for my network. when ever i try to create a pptp connection to a server on the internet it hangs on verifying username and password it then disconnect me with error unsuccessfull.
i have read i need to allow pptp passthrough just not sure how to configure it, i have looked through the forum with no luck as of yet .
pls if anyone could help i would be very thankfull
What error code do your receive, is it error 691 os else ?
Regards.
Faton
yes thats correct
‘ip firewall service-port set pptp disabled=no’
‘ip firewall service-port set gre disabled=no’
error code 691 means username or password is incorrect, so you can troubleshoot pptp issues based on error codes.
Regards.
Faton
