PPTP performance
We have a x86 based Mikrotik (Powerrouter732) that we are contemplating using as a VPN aggregator. When using it as a PPTP server with RB450 as the client device VPN throughput is less than desirable. When using Windows based VPN (client is XP, server is 2003) throughput is much greater.
Poor throughput (PPTP No Encryption)
RB450G <–ethernet–> cable modem -----(Internet)--------[ISPs Adtran]<—ethernet---->PowerRouter732
Good Throughput (Microsoft PPTP)
Windows7 <–ethernet–> RB450G <–ethernet–> cable modem -----(Internet)--------[ISPs Adtran]<—ethernet---->PowerRouter732<—ethernet—> windows server 2003
What is poor and what is good?
Is Windows computer technical specification similar to RB450?
7mbps windows vpn vs 300kbps mikrotik vpn
both tests done with btest. I suspect MTU as being the culprit.. but not sure.
It would be great you can contact MikroTik support (support@mikrotik.com).
Make support output file from RB450G and include short problem description.
