PPTP Problem! Urgent...
Dear All,
i’ve setup a vpn server on mikrotik 2.9.x and I got everything to be working from local, say if I connect from a local workstation to mikrotik through vpn (pptp), it works and I got an IP address from the pool…
but i want to connect from the internet I got this error log
21:09:34 pptp,ppp,debug VPN: <196.xx.xx.xx>: LCP timer
21:09:34 pptp,ppp,debug,packet VPN:      <0x0d 03 06><196.xx.xx.xx>: sent LCP ConfReq id=0x1
21:09:34 pptp,ppp,debug,packet VPN:    <mru 1460>
21:09:34 pptp,ppp,debug,packet VPN:    <magic 0x419ac241>
21:09:34 pptp,ppp,debug,packet VPN:    <auth  mschap2>
21:09:34 pptp,ppp,debug,packet VPN: <196.xx.xx.xx>: rcvd LCP ConfReq id=0x0
21:09:34 pptp,ppp,debug,packet VPN:    <magic 0x448215>
21:09:34 pptp,ppp,debug,packet VPN:    <pcomp>
21:09:34 pptp,ppp,debug,packet VPN:    <accomp>
21:09:34 pptp,ppp,debug,packet VPN:    <mrru 1614>
21:09:34 pptp,ppp,debug,packet VPN:    <ed 0x01 b5 5a e5 df 90 5f 4f bc 8e 92 00 37 57 be e4 09 00 00 00 07>
21:09:34 pptp,ppp,debug,packet VPN:      <0x0d 03 06><196.xx.xx.xx>: sent LCP ConfRej id=0x0
21:09:34 pptp,debug,packet VPN: rcvd Set-Link-Info from 196.201.139.162
21:09:34 pptp,debug,packet VPN:     peers-call-id=14
21:09:34 pptp,debug,packet VPN:     send-accm=0xffffffff
21:09:34 pptp,debug,packet VPN:     receive-accm=0xffffffff
21:09:34 pptp,debug,packet VPN: sent Set-Link-Info to 196.xxx.xx.xx
21:09:34 pptp,debug,packet VPN:     peers-call-id=1032
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: LCP timer
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: LCP timeout waiting initial data
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: LCP lowerdown
21:09:35 pptp,ppp,info <pptp-0>: terminating...
21:09:35 pptp,ppp,info VPN: <pptp-0>: terminating...
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: PPP disconnected <>
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: PPP destroy
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: PPP stopped
21:09:35 pptp,ppp,info <pptp-0>: disconnected
21:09:35 pptp,ppp,info VPN: <pptp-0>: disconnected
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: CCP lowerdown
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: CCP down event in initial state
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: IPCP lowerdown
21:09:35 pptp,ppp,debug VPN: <196.xx.xx.xx>: IPCP down event in initial state
I followed every single step posted on the documentation of pptp on mikrotik
thanks in advance
Yep, I’ve tried doing the same thing and ran into the same problem and could never get it working. I eventually gave up spending time trying to work it out and went with a different VPN solution.
:frowning:
what was tht different vpn solution?
i have seen no issues with vpn it is my favorit part of the os
you are using router to router vpn, or client to router? and does this client connect behind masqeuraded network? please let me know abt your issue
thank you
