Hello!
I have PPTP tunnel between two mikrotik routers. Everything worked OK but tunnel suddenly stopped working.
Log from PPTP Server :
TCP connection established from… (repeated +/- every 2 minutes)
Log from PPTP Client:
pptp-out1:initializing…
pptp-out1:connecting… (waiting)
pptp-ou1:terminating…-disconnected
Mikrotik’s reboot don’t change anything.
Can anybody help me?
Try adding pptp logging. Then you might see what happens on both mikrotiks when the disconnection happens.
Why do you have firewall between routers?
how is the setup? internet—mikrotik—firewall—mikrotik?
What firewall are you using?
I think problem is in “firewall machine”.
Now everything is OK, but when I lost internet connection between Mikrotik’s tunnel won’t start normally.
Thanks for helping me.
