PPTP problem.
Ok, I have two problems with PPTP.
I am putting a 450G into place to replace some ancient technology (RRAS 2008 actring as router, plus a AVM).
The 450G is supposed to connect to a RRAS in the company headquarters.
2 problems with this:
  • It sometimes fails to work. Connections get established, time out, establish, time out, then at the ent it says "could not determine remote address, using x.x.x.x and it works from there. Windows connects in seconds, so this is properly set up. I am at a loss here where the timeouts come from. Takes 2-3 minutes until one connect “goes through”.
  • I have a problem routing additional networks. I use 172.20 on my end, 172,21 on the office, but also 172.25 there. 172.25 is routed there, but it fails to go through. I am at a loss here. Any way to see how a subnet is routed?
