PPTP problems
I am having some PPTP problems. Two MT-routers conncted trough PPTP tunnel and it some times works for days. But most of the time it is not able to connect. On the server side I have a log like that:
IF ANYBODY HAS A SOLUTION FOR THAT PLEASE …
javascript:emoticon(‘:?:’)
Question
Regards
Christian
10:37:21 l2tp,debug,packet tunnel-id=43262, session-id=0, ns=0, nr=1
10:37:21 l2tp,debug,packet (M) Message-Type=SCCRP
10:37:21 l2tp,debug,packet (M) Protocol-Version=0x01:00
10:37:21 l2tp,debug,packet (M) Framing-Capabilities=0x1
10:37:21 l2tp,debug,packet (M) Bearer-Capabilities=0x0
10:37:21 l2tp,debug,packet Firmware-Revision=0x1
10:37:21 l2tp,debug,packet (M) Host-Name=“Router2”
10:37:21 l2tp,debug,packet Vendor-Name=“MikroTik”
10:37:21 l2tp,debug,packet (M) Assigned-Tunnel-ID=19240
10:37:21 l2tp,debug,packet (M) Receive-Window-Size=4
10:37:21 l2tp,debug,packet rcvd control message from 192.168.1.1:1701
10:37:21 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
10:37:21 l2tp,debug,packet (M) Message-Type=SCCRQ
10:37:21 l2tp,debug,packet (M) Host-Name=“MikroTik”
10:37:21 l2tp,debug,packet (M) Assigned-Tunnel-ID=43262
10:37:21 l2tp,debug,packet sent control message (ack) to 192.168.1.1:1701
10:37:21 l2tp,debug,packet tunnel-id=43262, session-id=0, ns=1, nr=1
10:37:29 l2tp,debug,packet sent control message to 192.168.1.1:1701
10:37:29 l2tp,debug,packet tunnel-id=43262, session-id=0, ns=0, nr=1
10:37:29 l2tp,debug,packet (M) Message-Type=SCCRP
10:37:29 l2tp,debug,packet (M) Protocol-Version=0x01:00
10:37:29 l2tp,debug,packet (M) Framing-Capabilities=0x1
10:37:29 l2tp,debug,packet (M) Bearer-Capabilities=0x0
10:37:29 l2tp,debug,packet Firmware-Revision=0x1
10:37:29 l2tp,debug,packet (M) Host-Name=“Router2”
10:37:29 l2tp,debug,packet Vendor-Name=“MikroTik”
10:37:29 l2tp,debug,packet (M) Assigned-Tunnel-ID=19240
10:37:29 l2tp,debug,packet (M) Receive-Window-Size=4
10:37:29 l2tp,debug,packet rcvd control message from 192.168.1.1:1701
10:37:29 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
10:37:29 l2tp,debug,packet (M) Message-Type=SCCRQ
10:37:29 l2tp,debug,packet (M) Host-Name=“MikroTik”
10:37:29 l2tp,debug,packet (M) Assigned-Tunnel-ID=43262
10:37:29 l2tp,debug,packet sent control message (ack) to 192.168.1.1:1701
10:37:29 l2tp,debug,packet tunnel-id=43262, session-id=0, ns=1, nr=1
10:37:29 l2tp,debug tunnel 19240 received no replies, disconnecting
10:37:29 l2tp,debug tunnel 19240 entering state: dead
10:37:29 pptp,info TCP connection established from 193.95.245.146
10:37:29 pptp,ppp,debug <193.95.245.146>: PPP started
10:37:29 pptp,ppp,info : waiting for call…
10:37:29 pptp,debug,packet rcvd Start-Control-Connection-Request from
193.95.245.146
10:37:29 pptp,debug,packet protocol-version=0x0100
10:37:29 pptp,debug,packet framing-capabilities=2
10:37:29 pptp,debug,packet bearer-capabilities=0
10:37:29 pptp,debug,packet maximum-channels=0
10:37:29 pptp,debug,packet firmware-revision=1
10:37:29 pptp,debug,packet host-name=ProPiar
10:37:29 pptp,debug,packet vendor-name=MikroTik
10:37:29 pptp,debug,packet sent Start-Control-Connection-Reply to
193.95.245.146
10:37:29 pptp,debug,packet result-code=1
10:37:29 pptp,debug,packet error-code=0
10:37:29 pptp,debug,packet host-name=Router2
10:37:29 pptp,debug,packet rcvd Outgoing-Call-Request from 193.95.245.146
10:37:29 pptp,debug,packet call-id=0
10:37:29 pptp,debug,packet call-serial-number=0
10:37:29 pptp,debug,packet minimum-bps=2400
10:37:29 pptp,debug,packet maximum-bps=10000000
10:37:29 pptp,debug,packet bearer-type=3
10:37:29 pptp,debug,packet framing-type=2
10:37:29 pptp,debug,packet packet-recv-window-size=100
10:37:29 pptp,debug,packet packet-processing-delay=0
10:37:29 pptp,debug,packet phone-number-length=0
10:37:29 pptp,debug,packet phone-number=
10:37:29 pptp,debug,packet subaddress=
10:37:29 pptp,ppp,debug <193.95.245.146>: PPP connected
10:37:29 pptp,ppp,debug <193.95.245.146>: LCP lowerup
10:37:29 pptp,ppp,debug <193.95.245.146>: LCP open
10:37:29 pptp,debug,packet sent Outgoing-Call-Reply to 193.95.245.146
10:37:29 pptp,debug,packet call-id=54765
10:37:29 pptp,debug,packet peers-call-id=0
10:37:29 pptp,debug,packet cause-code=0
10:37:29 pptp,debug,packet connect-speed=100000
10:37:29 pptp,debug,packet physical-channel-id=0
10:37:30 pptp,ppp,debug <193.95.245.146>: LCP timer
10:37:30 pptp,ppp,debug,packet <193.95.245.146>: sent LCP ConfReq id=0x1
10:37:30 pptp,ppp,debug,packet <mru 1024>
10:37:30 pptp,ppp,debug,packet <magic 0x22f1cae0>
10:37:31 pptp,ppp,debug <193.95.245.146>: LCP timer
10:37:31 pptp,ppp,debug <193.95.245.146>: LCP timeout waiting initial data
10:37:31 pptp,ppp,debug <193.95.245.146>: LCP lowerdown
10:37:31 pptp,ppp,info : terminating…
10:37:31 pptp,ppp,debug <193.95.245.146>: PPP disconnected <>
10:37:31 pptp,ppp,debug <193.95.245.146>: PPP destroy
10:37:31 pptp,ppp,debug <193.95.245.146>: PPP stopped
10:37:31 pptp,ppp,info : disconnected
10:37:31 pptp,ppp,debug <193.95.245.146>: CCP lowerdown
10:37:31 pptp,ppp,debug <193.95.245.146>: CCP down event in initial state
10:37:31 pptp,ppp,debug <193.95.245.146>: IPCP lowerdown
10:37:31 pptp,ppp,debug <193.95.245.146>: IPCP down event in initial [/b] :question: :question: :question: :question:
