Hi. I have a CRS125-24G-1s Running v6.47.1. I have Split the Router in to two groups. Ports 1-8 are a private network for ham radio and 9-24 are for my home network. I have setup PPtP for access to the ham ports (1-8) with the Wan on eth1 and ports 2-8 on the bridge HAM-Bridge. I have DHCP running to provide address in the 192.168.10.0/24 subnet on HAM-Bridge. I have a pool of addresses for the VPN at 192.168.11.0/24 The wan address is static and attached directly to my cable modem. The ports 9-24 are in Office-Bridge and are attached to another Mikrotik router via port 9.
From outside of my network I can VPN in to the HAM-Bridge and get assigned a 192.168.11.xx address and I can ping to all the devices in the 192.168.10.0 network. Perfect Just as it should be.
If I try the same thing from a PC connected to the Office-Bridge on a local address of 192.168.104.xx I can connect to the VPN and get a 192.168.11.xx address assigned but I CAN NOT ping or connect to any devices in the VPN target network of 192.168.10.xx network.
I suspect a routing problem of some sort that is specific to having both HAM-Bridge and Office-Bridge on the same switch but I can’t figure out what I am missing.
Thanks in advance for any help.
