Pptp user:
Local ip: 192.168.0.161
Remote ip: 192.168.0.162
Problem:
When connected to pptp, user can only ping LAN, not LAN2. When I assign a 192.168.1.0/24 addy to pptp user, it can only ping that range, not the other.
When connected by cable or wireless, everything works fine.
The router in question is about 400km from here and the customer is very dependant on it. I am a bit cautious to make drastic changes to it.
Do you suggest I bridge lan and lan2?
The reason they have two subnets is a weighing system with hard coded ip address (0.x) and an oldish network with ip cameras (1.x) etc. Both of these systems have to be accessed remotely.
As a temporary workaround, i have created two pptp users in different subnets. One for the cameras and one for the weighing sytem, but this is not ideal.
Any help will be appreciated. I am sure this is not a difficult problem for seasoned forumites.
I would be separating the VPN subnet, my rule of thumb is every interface should have it’s own network, PPTP/VPN is no different, unless you have some specific reasons for keeping it the same as the LAN.
