PPTP server behind 1:1 nat
I have a MT pptp-client with static public ip address on its wan, trying to connect a MT pptp-server behind a 1:1 natted ISP router.
Client hangs on “link established”
After first data exchange, client hangs in
sent LCP ConfReq  id=0x20
<mru 1450>
<magic 0x35bc8ec0>
LCP open
port 1723 TCP and GRE protocol accept rules are ok on input chain of server
Is the issue caused by NAT on server side ?
Other MT pptp servers are working fine when public ip is configured directly on wan interface (not natted) .
Tried also to work with /ip firewall service-port pptp helper, nothing changed (perhaps service-port is used for forward ?)
Don’t know what else to try…
The ISP device, does it have such pptp helper checkbox?
Use sniffer tool on both ends to see which side sends/receives GRE protocol packets. They might get blocked somewhere in between , probably on ISP router
The ISP device is a silly Vodafone Station with MT PPtP server (RB3011) in its DMZ address.
I’m able to connect my RB3011 from my iPhone L2TP/ipsec client as well as bring up a GRE/ipsec static tunnel from a remote RB3011
No luck with third 3011 running PPTP client stuck in situation reported…
Is there perhaps a problem running PPTP server at same time with a L2TP server or existing GRE ?
There is no such problem on the MikroTik router but I know of plenty of problems with NAT and “DMZ” settings in consumer-grade routers.
PPTP on such a NAT router will normally only work on the client side, not when the router is on the server side.
When you are faced with such a router it is better to not use technologies like PPTP (which should be deprecated anyway).
Try to use SSTP instead when you cannot use L2TP/IPsec.
