This is from the RB450 (main office)
[admin@MikroTik] > /interface print detail
0 R name="ether1-gateway" type="ether" mtu=1500 l2mtu=1524
1 R name="ether2-master-local" type="ether" mtu=1500 l2mtu=1524
2 R name="ether3-slave-local" type="ether" mtu=1500 l2mtu=1524
3 name="ether4-slave-local" type="ether" mtu=1500 l2mtu=1524
4 name="ether5-slave-local" type="ether" mtu=1500 l2mtu=1524
5 name="pptp-in1" type="pptp-in"
6 DR name="<pptp-yarmouth>" type="pptp-in" mtu=1460
7 DR name="<pptp-ohg>" type="pptp-in" mtu=1460
This is /IP ADDRESS PRINT DETAIL
[admin@MikroTik] > /ip address print detail
0 address=192.168.254.1/24 network=192.168.254.0 interface=ether2-master-local
actual-interface=ether2-master-local
1 D address=213.123.115.166/24 network=213.123.115.0 interface=ether1-gateway
actual-interface=ether1-gateway
2 D address=172.16.3.1/32 network=172.16.3.2 interface=<pptp-yarmouth>
actual-interface=<pptp-yarmouth>
3 D address=172.168.1.1/32 network=172.168.1.2 interface=<pptp-ohg>
actual-interface=<pptp-ohg>
Route Detail
[admin@MikroTik] > /ip route print detail
0 A S dst-address=0.0.0.0/0 pref-src=213.123.115.166 gateway=ether1-gateway
gateway-status=ether1-gateway reachable distance=1 scope=30
target-scope=10
1 ADC dst-address=172.16.3.2/32 pref-src=172.16.3.1 gateway=<pptp-yarmouth>
gateway-status=<pptp-yarmouth> reachable distance=0 scope=10
2 ADC dst-address=172.168.1.2/32 pref-src=172.168.1.1 gateway=<pptp-ohg>
gateway-status=<pptp-ohg> reachable distance=0 scope=10
3 ADS dst-address=192.168.250.0/24 gateway=172.16.3.2
gateway-status=172.16.3.2 reachable <pptp-yarmouth> distance=1 scope=30
target-scope=10
4 S dst-address=192.168.250.0/24 gateway=172.16.3.2
target-scope=10
5 DS dst-address=192.168.252.0/24 gateway=172.16.1.2
gateway-status=172.16.1.2 unreachable distance=1 scope=30
target-scope=10
6 ADC dst-address=192.168.254.0/24 pref-src=192.168.254.1
gateway=ether2-master-local gateway-status=ether2-master-local reachable
distance=0 scope=10
7 ADC dst-address=213.123.115.0/24 pref-src=213.123.115.166
gateway=ether1-gateway gateway-status=ether1-gateway reachable
distance=0 scope=10
IP FIREWALL EXPORT
[admin@MikroTik] > /ip firewall export
# aug/25/2011 07:45:23 by RouterOS 5.5
# software id = 0N2S-Y19T
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="From our LAN" disabled=no in-interface=ether2-master-local \
src-address=192.168.254.0/24
add action=accept chain=input disabled=no dst-port=1723 protocol=tcp
add action=accept chain=input disabled=no protocol=gre
add action=drop chain=input disabled=no in-interface=ether1-gateway src-address=89.207.130.17
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-gateway \
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
INTERFACE PPTP-SERVER
[admin@MikroTik] > interface pptp-server export
# aug/25/2011 07:47:09 by RouterOS 5.5
/interface pptp-server
add disabled=no name=pptp-in1 user=""
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=yes \
keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
[admin@MikroTik] >
No pptp-client data on the office router.
All above are from Main office router.
What follows below is the remote router:
[admin@00:0C:42:9C:7D:AB] > /interface print detail
0 name="wlan1" type="wlan" mtu=1500 l2mtu=2290
1 name="wlan2" type="wlan" mtu=1500 l2mtu=2290
2 R name="ether1" type="ether" mtu=1500 l2mtu=1526
3 name="ether2" type="ether" mtu=1500 l2mtu=1522
4 name="ether3" type="ether" mtu=1500 l2mtu=1522
5 R name="office" type="pptp-out" mtu=1460
6 R name="wifi" type="bridge" mtu=1500 l2mtu=65535
[admin@00:0C:42:9C:7D:AB] > /ip address print detail
0 ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 interface=ether1
1 ;;; hotspot network
address=10.10.10.1/24 network=10.10.10.0 interface=wifi
actual-interface=wifi
2 address=192.168.250.1/24 network=192.168.250.0 interface=ether1
3 D address=192.168.1.66/24 network=192.168.1.0 interface=ether1
4 D address=172.16.3.2/32 network=172.16.3.1 interface=office
actual-interface=office
IP ROUTE PRINT DETAIL
[admin@00:0C:42:9C:7D:AB] > /ip route print detail
0 ADS dst-address=0.0.0.0/0 gateway=192.168.1.254
gateway-status=192.168.1.254 reachable ether1 distance=0 scope=30
target-scope=10 vrf-interface=ether1
1 ADC dst-address=10.10.10.0/24 pref-src=10.10.10.1 gateway=wifi
gateway-status=wifi reachable distance=0 scope=10
2 ADC dst-address=172.16.3.1/32 pref-src=172.16.3.2 gateway=office
gateway-status=office reachable distance=0 scope=10
3 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.66 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
4 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=ether1
5 ADC dst-address=192.168.250.0/24 pref-src=192.168.250.1 gateway=ether1
IP FIREWALL EXPORT
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=10.10.10.0/24
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no \
PPTP-CLIENT
/interface pptp-client
add add-default-route=no allow=pap,chap,mschap1,mschap2 connect-to=\
213.123.115.166 dial-on-demand=no disabled=no max-mru=1460 max-mtu=1460 \
mrru=disabled name=office password=******** profile=default-encryption user=\
Thats the lot - any insights greatly appreciated.
