PPTP Server issue: cannot access LAN after connection
I have successfully setup a PPTP server on my RB750GL and can connect to it. However, I cannot access any LAN devices and there doesn’t seem to be any traffic going out from the RB750 to my PPTP client.
I basically turned on the PPTP server and set up a secret with username and password, using the default-encryption profile, and put in a local and remote address which are on my LAN subnet.
At this point I can connect, but nothing seems to make it back to my client. I can see that my pings are coming through the dynamic pptp interface on the 750, but nothing comes back. It looks like they may be going out the WAN interface instead.
I believe my default drop rule for the forward chain is killing the tunnel. I’m not sure how to properly fix this though. It seems that once the packet comes out of the tunnel it doesn’t match against gre so my attempt at a forward rule fails.
Does someone know how to properly allow pptp traffic to get back out to the client?
Thanks.
If this isn’t layer 2 then you’ll need routes on both sides to the networks behind the PPTP tunnels.
I’ve definitely narrowed it down to the firewall rules. I have an input rule accepting tcp 1723 and that allows the pptp connection in the first place, but I also have a series of forward rules allowing connection to internal servers on specific ports on my lan segment and dmz segment. That all works fine.
The problem is the only way I’ve figured to allow pptp traffic is to forward anything with a src address matching my VPN IP range. If I remove that rule things will quit working as they hit the bottom drop rule on the forward chain. I was thinking there might be a more elegant way of allowing VPN traffic through the firewall, but maybe this is the best way?
PPTP consists of tcp/1723 for the control channel, and GRE (IP protocol 47) for the data channel.
Don’t forget to set up your interface for proxy-arp
Interfaces → Ether2 ( your interface ) → ARP : Proxy-arp
