PPTP Uptime
When I monitor my PPTP tunnel, the uptime will get to 30sec then disconnect, and reconnect.
What do I need to change so this will stay connected?
PPTP CLIENT end:
echo: pptp,ppp,info tunnel: terminating... - keepalives timed out
echo: pptp,ppp,info tunnel: disconnected
echo: pptp,ppp,info tunnel: initializing...
echo: pptp,ppp,info tunnel: dialing...
echo: pptp,ppp,info tunnel: authenticated
echo: pptp,ppp,info tunnel: connected
I have changed the keepalive on the server end with no luck.
Is there another keepalive value somewhere else?
From the changelog for 2.9.20
*) fixed PPTP client to not disconnect every 30s on some occasions;
Regards
Andrew
