PPTP VPN access to VLANs
Hello
I just got 2 routerboards and I ran into some problem.
After creating PPTP VPN, I can not access the network connected to eth5 or the VLAN. Whatever is in the same subnet I can access without any problems.
/interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU
 0  R  WAN                                 ether            1500  1598       4074
 1  RS ether2-master-local                 ether            1500  1598       4074
 2  RS ether3-slave-local                  ether            1500  1598       4074
 3   S ether4-slave-local                  ether            1500  1598       4074
 4  R  ether5-Apartments                   ether            1500  1598       4074
 5  RS ether6-master-local                 ether            1500  1598       2028
 6  RS ether7-slave-local                  ether            1500  1598       2028
 7  RS ether8-slave-local                  ether            1500  1598       2028
 8  RS ether9-slave-local                  ether            1500  1598       2028
 9   S ether10-slave-local                 ether            1500  1598       2028
10 DR  <pptp-vaios>                        pptp-in          1400
11  R  bridge-local                        bridge           1500  1598
12  R  guest-vlan                          vlan             1500  1594
13  R  pppoe-out1                          pppoe-out        1480
Proxy-arp is enabled on bridge-local, guest-vlan, and eth5
/ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; Atrium mgmt
     192.168.9.1/24     192.168.9.0     ether2-master-local
 1   ;;; guest vlan
     192.168.209.1/24   192.168.209.0   guest-vlan
 2   ;;; Apartments
     192.168.14.254/24  192.168.14.0    ether5-Apartments
 3 D 94.68.XX.XX/32   80.XX.XX.XX   pppoe-out1
 4 D 192.168.9.1/32     192.168.9.81    <pptp-vaios>
 /ip pool print
 # NAME                                           RANGES
 0 mgmt                                           192.168.9.101-192.168.9.121
 1 vpn                                            192.168.9.80-192.168.9.90
 2 guests                                         192.168.209.101-192.168.209.254
 3 apts                                           192.168.14.101-192.168.14.151
PPTP Configuration
/ppp profile print
Flags: * - default
 0 * name="default" use-mpls=default use-compression=default
     use-encryption=default only-one=default change-tcp-mss=yes
     use-upnp=default address-list="" on-up="" on-down=""
 1   name="vpn-profile" local-address=192.168.9.1 remote-address=vpn
     bridge=bridge-local use-mpls=default use-compression=default
     use-encryption=required only-one=default change-tcp-mss=default
     use-upnp=default address-list="" dns-server=192.168.9.1 on-up=""
     on-down=""
/interface pptp-server server print
            enabled: yes
            max-mtu: 1450
            max-mru: 1450
               mrru: disabled
     authentication: mschap1,mschap2
  keepalive-timeout: 30
    default-profile: vpn-profile
My problem is that I can not access any device connected to eth5 or anything in the VLAN *except when I use “use default gateway on remote network” option in windows settings, something that I don’t want to have enabled.
I plan to use a site to site PPTP link (with a new RB3011) aswell and I need full access to the other networks.
How can I fix that?
Thank you in advance
