I’ve definitely forgotten something simple here. I have a working PPTP server set up, but I can’t reach the web GUI of a DVR on that network, but I can ping it and I CAN reach it remotely through port forwarding from anywhere. At first I couldn’t ping anything except the router, but the router could ping everything on the network… figured out that I had to enable proxy-arp on ether2.
What could be keeping me from reaching the DVR’s web interface? I get a generic “could not connect” error in Chrome. I’ve tried two different locations with identical hardware and am getting the same thing in both.
RB750GL (LAN address 192.168.88.1)
PPTP server enabled
one Secret set up to use pptp service and default-encryption profile
default-encryption profile uses local address 192.168.88.20 (I had it at .88.1, but was testing things) and remote address from a “VPN” pool of 192.168.88.21-192.168.88.29
ether2 set to proxy-arp
When connected a dynamic Route gets created for 192.168.88.21. All other routes end in “/24” and I’m not sure why this one doesn’t. I have [what I think is] an identical setup on another RB750GL that is running 5.9 and it gets a dynamically created route that ends in “/32”. This one is running 5.16 and I’m not sure if that is just a difference between versions or if it’s a symptom of me having something set wrong.
Any ideas?
