PPTP vpn client on Mikrotik stuck at "dialling..."
I’ve got 2 different VPN services provided at work (one by my dept, one centrally). I can’t connect to either of them. :frowning:
I’ve got a little Mikrotik doing NAT for my home network, as well as running its PPTP server so I can get in from work.
But every time I try to enable the VPN client in the Mikrotik, it gets stuck at the “dialling…” stage, and won’t connect. If I connect the VPN from a Mac on my home network, the VPN connection works every time. So there’s nothing wrong with the VPN servers at work, they are okay.
Anyone else seen this problem please?
I’ve attached a shot of the PPTP logs from the Mikrotik, so you can see where it stops. What is supposed to be the next log output?
Thanks!
Jules.
If I create a new VPN client in WebFig, it connects first time. If I then disable it, click Apply, enable it again, click Apply, it now gets stuck at dialling… until I reboot again.
Me spies a bug. :frowning:
I’m apparently running 5.26, but any and all upgrade checks tell me there’s nothing newer available and I’m up to date. All packages are dated Sept 14 2013.
