PPTP vpn, DHCP Pool
I’m a new Microbic User,
I bought 2 HEX router to extend a network from office to multiple location using VPN, what i try to do is a PPtP VPN, i first bought only 2 routers, but in the futur i will bought 5 to 10 others for expend the network
on my office i will use 192.168.88.1 network, i want to use this dhcp pool for all of my other location, i want my office router to be the dhcp for all location,
i want to use all the same network on each location, i dont want to use Nat, for many reason, the equipment that i use need to be on the same network to be discover
how can i program my router on my first site to connect on my office and when i plus my equipement into it, i will receive an ip address from my office
thank,
Please use PTP Tunnel like IPSec, EoIP as per your requirement
PPTP is not your require option.
Did someone can reply with an example to tell me how to program it
There are a lot of tutorials on the Internet, this one helped me a lot:
https://www.techonia.com/6034/configure-mikrotik-l2tp-server-ipsec
