PPTP VPN Help
When connecting to PPTP VPN I can only connect to web admin of other devices, i.e. switches, if I have “Use default gateway on remote network” under TCP/IP Settings checked, which settings do you need to implement to be able to not use remote gateway and still reach other devices.
Thank you in advance for any help!
http://mikrotikroutersetup.blogspot.com/p/mikrotik-router-pptp-remote-access-vpn.html
