I’m having a peculiar problem - I have a RB450G running RouterOS 4.11.
This router is the main router for this company I support. They have an internal Microsoft RRAS server to terminate VPN traffic.
The RB450G is natted with 2 x dstnat:
PPTP (1723) to the internal RRAS server
GRE to the same RRAS server
The IP Firewall accepts (input) both PPTP and GRE
Situation:
Some people can connect without any problems
Some people can connect, but then after 1-2 minutes it drops
some people cannot connect at all.
I initially suspected either user’s routers or ISP - But as it turns out, if I replace the RB450G by a generic linksys with NAT forward 1723 and PPTP pass-thru enabled, it works perfectly for everyone!
I’m running v4.13, with PPTP tunnel to Windows 7 client.
After about 1 min if activity the PPTP connection will have completely lost any activity.
If a client connects, and within 1min, I start a ping, no problems, connection will work fine until idle time reaches 1min again, then all activity is lost again.
Basically, what I was finding was: if idle time exceeded 1min on a pptp connection, all communication was “silently dropped” by the router.
To solve this, I run a script on the server (Mikrotik RouterOS) every 45sec (< 1min) to ping out the pptp interface(s), and it seems to work great, so far connections have been up for weeks without any problems.
Not sure if this is related, but it helped me.
I looked over the debug logs, and I’m trying to determine what the root cause is, but the logs don’t show much. I haven’t reported this to support yet, because I’m trying to gather more data, and run some more tests.
A Linksys at the remote site, or a Cisco PIX will create that behavior:
PC -----NAT ------LINKSYS or Cisco PIX-----------------Internet -------------Microtik---------NAT---------RRAS
…even with VPN pass-thru enabled on the “home” device.
So far, I have established that the problem goes away with:
netgear router
Verizon-branded router
DD-WRT (same “linksys” hardware that was causing a problem; so it’s not the hardware, but rather the firmware)
The error occurs at the “verifying username / password” - therefore, it seems the GRE protocol is at fault, not correctly being passed through the Microtik, even with a specific dstnat (redirect) of GRE (protocol 47).
Do “Cisco-based” firmwares somehow encapsulate GRE differently than other routers? Let me repeat that if, instead of a Microtik, I use a linksys (just for testing), then the redirect works well - so it’s not the way the “home router” encapsulates the GRE traffic as much as the way the Microtik “recognizes” that kind of encapsulation? Hm – That’s for someone more qualified than me to answer…
For now, since I didn’t want to start policing which “soho house router” my remote users bought, I personally did this to fix the problem (regardless of the brand of router used on the other end):
Setup the RB450G as PPTP server
Use RADIUS against the internal RRAS server for authentication (IAS) - this maintains single sign-on
(I’ll create a “how to” document if someone is interested?)
Others will need to answer this, as I have already moved to stop the redirection, and instead configured the RB as PPTP server with RADIUS (as mentioned earlier). It works well and now I just want to leave my (very happy) users alone
I’m not certain if this is the most recent discussion on this, but I’m having this exact same issue with my RB750GL. I was hoping to replace my old Netopia router with a Mikrotik, but I did and now I have 2 people that can’t connect to my pptp vpn. Both people are using Comcast SMC Business Gateways as their routers. Not sure if I’ll run into other routers with same issue, but I can’t just hope for the best. I have to switch away from Mikrotik unless there’s a solution. I have many other people working fine through the existing RB750GL dst nating to a server 2008 VPN server.
I use SSTP when possible, but it’s not always possible for everyone. I do not want to run the vpn server on the Mikrotik.
Recently I changed the old soho routed D-link with Mikrotik and now I have the same problem. No way how to enable passthrough for my VPN.
PC - internet - Mikrotik - VPN(Synology) - LAN
The connection can not be established.
The Firewall NAT configuration:
0 ;;; default configuration
chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=ether1-gateway
