I’ve have my PPTP setup on my RB450G and it has been working great for the last 6 months. I moved to a new place (same city) and seem to be having issues now. I have my Mikrotik behind a 2wire gateway and it’s in the DMZ. (There’s no way to fully bridge it, I’ve tried) When I try to vpn in, it gets stuck at the verifying username and password stage and gives me an 806 error (using Windows 7 to connect) When I take a look at the connections I can see the remote IP trying to connect via 1723 and GRE but it won’t connect. Specifically what I see is in the picture attached. The IPs are on the same ISP and blacked out, but one is the remote and one is my WAN IP. Any insight into what is going on?
[admin@MikroTik] /ip> firewall nat print
0 ;;; Added by webbox
chain=srcnat action=masquerade out-interface=WAN
1 chain=srcnat action=masquerade protocol=tcp src-address=192.168.1.0/24 dst-address=192.168.1.60 out-interface=WAN dst-port=80
2 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=3389 protocol=tcp in-interface=WAN dst-port=3389
3 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=80 protocol=tcp in-interface=WAN dst-port=80
4 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=443 protocol=tcp in-interface=WAN dst-port=443
5 chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=1194 protocol=udp in-interface=WAN dst-port=1194
6 X chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=135 protocol=tcp in-interface=WAN dst-port=135
7 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=987 protocol=tcp in-interface=WAN dst-port=987
8 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=21 protocol=tcp in-interface=WAN dst-port=21
9 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=9987 protocol=udp in-interface=WAN dst-port=9987
10 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=10011 protocol=tcp in-interface=WAN dst-port=10011
11 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=2302 protocol=udp in-interface=WAN dst-port=2302
12 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=27015-27022 protocol=tcp in-interface=WAN dst-port=27015-27022
13 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=27015-27022 protocol=udp in-interface=WAN dst-port=27015-27022
14 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=1100-1120 protocol=tcp in-interface=WAN dst-port=1100-1120
15 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=10011 protocol=udp in-interface=WAN dst-port=10011
16 chain=dstnat action=dst-nat to-addresses=192.168.1.60 to-ports=9101 protocol=tcp in-interface=WAN dst-port=9101
17 chain=dstnat action=dst-nat to-addresses=192.168.1.50 to-ports=3389 protocol=tcp in-interface=WAN dst-port=3390
18 chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=444 protocol=tcp in-interface=WAN dst-port=444
[admin@MikroTik] /ip> firewall filter print
0 chain=input action=drop protocol=tcp dst-port=22,23
1 chain=forward action=accept connection-state=established
2 chain=forward action=accept connection-state=related
3 chain=forward action=drop connection-state=invalid
4 ;;; Prevent inter-subnet communication
chain=forward action=drop src-address=192.168.1.0/24 out-interface=!WAN
5 ;;; Prevent inter-subnet communication
chain=forward action=drop src-address=10.0.0.0/24 out-interface=!WAN
6 chain=input action=accept protocol=gre
