I have established a PPTP vpn connection from my xp machine to a 532 router. but I can not see past the 172.16.16.1 (default gateway)interface to devices on the net work. I’ll so get a strange IP setup … x.x.x.1 should be the gatway and there are no leases showing in the lease table for this network. I have tried it both through my fire wall and with a direct connection to the net. same results. there are no firewall rules in place yet.
PPP adapter Virtual Private Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 172.16.16.103
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 172.16.16.103
DNS Servers . . . . . . . . . . . : 204.16.147.1
204.16.144.131
Is this ip setup normal and if so why and where is it comming from and any ideas as to why I can not acess other divices on the 172.16.16.x network?
