PPTP VPN Problem
I made a PPTP VPN Server on my MIKROTIK RB 951-2n router and I am able to connect on my VPN using windows software client VPN connection. I can ping my router but I can not ping any single PC in my private network. I think that the problem is in Mikrotik Firewall but I don know what to do.
I need help?
paste you firewall fliter setting
Are you connecting directly to the VPN server with a Windows computer? Did you add a route to the VPN server localnet in that computer?
I use tracert (command prompt program) to troubleshoot VPNs. It will show you where the route to the localnet is failing.
Howdy,
Proxy-arp set on the office LAN interface?
Examples are on the wiki.
I would guess that your issue is with routing. Check the route tables on the computers to be sure that they are routing the traffic through the VPN.
Sent from my iPhone using Tapatalk
