In the following pictures i describe my 2 networks and my problem.
Do you have any idea?
Thank you.
Thank you.
Add a route to the Vigor 2820 (whatever that is) pointing 192.168.100.0/24 through 192.168.27.11.
You’ll also want to edit the NAT rules on the RB433AH to exclude traffic from 192.168.100.0/24 to 192.168.27.0/24 from NAT:
add chain=srcnat src-address=192.168.100.0/24 dst-address=192.168.27.0/24 place-before=0 action=accept
Note that the above command will break traffic from PC2 to PC1 as well until you have added the static route on the Vigor router.
Hello fewi, thanks for the answer.
I have already added the route in the vigor 2820 (check picture #3).
I also added the command that you told me, but now PC2 can’t see PC1 (as you said).
Then the Vigor router doesn’t look for 192.168.27.11 via a PPTP tunnel but sends the packet out the LAN interface, which won’t work. Looks like a platform limitation on that router. If it permits it, you can set a different IP pool for PPTP clients and try to route via that.
No, i don’t think that vigor sends the packets out from the LAN interface.
In static route that i added i’ve selected WAN1 as out interface, not LAN.
