Hello everyone,
When I make a pptp vpn connection my speed drops to 10 Mbps instead of 100 Mbps (home network). I notice that I go via the gateway of the external network instead of my own. Does anyone knows what I can do to change this? To change the gateway to my own gateway?
It would be a great help!
Hello, this is the default configuration. if you want your own gateway, you have to change it in the properties of your NIC, and then add a route to join your remote subnet.
You should disable ‘Use default gateway on remote network’ option in VPN settings on client computer.
How to
