pre-paid cards
I want to make pre-paid cards for costumers using my wireless network,how i can do tht using mikrotik 4.6 version?
UserManager.
Print a load of cards with Codes on them.
Add the Codes to UserManager.
Set access based on UserManager/Radius.
The cards run out after Xhours or Xdays.
Customer buys new card.
Simples.
Popular request…
Look at http://forum.mikrotik.com/t/voucher-with-serial-numbers/24018/1
Havent had an update on the code I sent… (more important things going on there…)
Expect this “post / thread” to be moved to UserManager…
Have a good one !!
I`m not an expert in network and mikrotik sysytem,I use PPPOE connection method,is it possible to use prepaid tickets also on this method?
nobody knows, including me.
basically you need to have a HotSpot page where the User can enter a Code.
Create a load of Codes, Print them on Cards and add them to some kind of Authentication system that the Mikrotik understands.
That could be as simple as typing them in as Users under IP->Hotspot->Users, Or add them to UserMananger, Or A N Other (and much better system, like VX)
There aren’t too many different ways to do it.
HotSpot is easiest IMHO.
