Currently if you replace a configured wireless card in a routerboard then the new card will be unconfigured and disabled. If you put the original card back in then the routerboard will “remember” the settings of the old card and not require configuration. Is there any way to preconfigure a card before inserting it to the routerboard so that once the new card is in place the mikrotik will “remember” the configuration for it, even though it has never been previously installed?
For example, I have a routerboard with an 802.11a card that I would like to replace with an 802.11n card. I would like to be able to add a configuration for the N card before physically inserting it, so that it requires no configuration after installation.
Thank you for the recommendation, but the solution I’m hoping for would not require me to log into the routerboard after installing the new card. The idea is to remove that step entirely so that the tech installing the card can simply swap the card and be done, without having to open a computer and log into the routerboard afterwards.
I did back in the days several posts about this issue, but no one from mikrotik ever took it into account. Dont bother even think about it - write your config to a file, and restore one by one.
If a field tech replaces a radio card, and that radio is how the box joins your network, then you won’t be able to ftp the auto.rsc file remotely; the field tech will have to do it.
Here is another approach that requires a little more setup, but will be much more turn-key for the installer:
Create & store the radio configuration as startup.rsc
Create a system script named “startup-config” that looks for startup.rsc, imports it, and then deletes it (or renames it to startup.bak, in case something goes wrong)
Create a scheduler event named “on-startup” that runs “startup-config” at start-time=startup
The field tech powers down the board, swaps radio cards, then powers it back up. The “on-startup” event runs at startup, which runs “startup-config”. That script finds and imports startup.rsc, then renames/deletes it. If you think there is a chance that the tech will need to power it up more than once, omit the rename/delete step, and the startup.rsc script will run every time the box is rebooted, until you can log on remotely and disable it.
As usual, scripting is left as an exercise for the reader, and the posting of successful solutions is encouraged.
Thanks for the ideas. I’m sure the scripting can be made as complicated as desired but I was able to achieve success with the following in a lab scenario.
Before tech goes out to replace card, export current wireless settings to file
Tech powers down routerboard, replaces card, powers up routerboard. New card is properly configured according to the exported settings. Scheduler is then disabled by remote office when it is determined to no longer be needed.
other settings tied to the interface are still lost, such as IP or bridge port, but you can add those settings to the import file or have the scheduler import multiple files on startup to restore additional settings.
I ran into issues when doing a large export. One easily reproducible error is with “/ip address”. If ether1 has 192.168.1.1, so the export contains “/ip address set 0 address=192.168.1.1”, then the import will error because the interface already has that IP address, causing the rest of the import to fail entirely.
which RouterOS version was the export from and which version you imported it into? Latest versions have “export compact” and there should be no such issues. Also what you can try is use “/system reset no-defaults=yes run-after-reset=import.rsc”
