Prepaid card - automatic expiration.
hi guys.
I want to print monthly access prepaid card which will only expire one month after the first login.
how to do that?
thanks
RADIUS
is there anyway to do that without radius? I can’t afford another server on network,
thanks
hotspot manager online service: http://www.mikrotik.com/download.html#hotspot
it is free and very useful.
so it is not actually possible to do so with version 2.8 or 2.9? without additional software and server, and I’ve notice hotspot manager needs radius? or how exactly does it work?
Mikrotik is a router, not a authentication server. It’s only normal that MT would not support this.
@Hellbound
wait! wrong. you only need to set up your router to connect to the hotspot manager. it IS a radius, you don’t need anything else. just create an account on the hotspot manager and start using it, you don’t need anything else.
and where exactly hotspot manager installed? on mikrotik.com?
yes. it is an online service, you log in, connect to your router, add your users and start controlling them and gathering statistics.
