prestera_dx_mac high load
hi all, what is prestera_dx_mac, i have high load on this process. last arm 7.18.1
any ideas?
regards
I have the exact same problem. Mikrotik CRS318-16P-2S+ with routerOS 7.18.2, in my case it is not directly associated with high traffic, is 20Mbps of traffic forwarding “no input” enough for it to appear pestera_dx_mac
Hi I had the same issue on my CCR2116-12G-4S v7.18.2 , I turned off the L3HW offloading on my switch settings as i am not using it and the cpu usage on pestera_dx_mac dropped to 0
Hi, only disable HW offload do not have effect here.
i have a bridge with 4 uplinks/ports and if traffic over 50mbit/s pestera_dx_mac CPU goes hight.
regards
Hi @all, no new informations here?
regards
