Prevent accidental deletion
I would like to know how to prevent or lock items against accidental deletion in winbox.
in old versions of winbox, had a “lock / unlock” button, not being able to find in new versions.
Thank you.
→ “Safe mode”
Or login with read-only user.
Not exactly the same. If you enable safe mode and delete something and then normally terminate management session, the setting is lost. safe mode only helps if, after you made a mistake, cut the management connection … only then ROS reverts the change.
Using RO user is better approach IMHO.
And le’ts not forget the undo / redo buttons.
