i have a very important CCR at a remote location. Did a few things to prevent accidential lockout by firewall rules. But I think it can happen very easily to disable the internet uplink by accidential clicking on the D left to the interfaces sfp1.
Is there a way to prevent this?
Else I will have to write a script that checks every minute status of sfp1 and reenables it if is disabled.
Regards
Martin
Doesn’t appear the skin can be modified to prevent this - for important routers I’d suggest not using Webfig in any case, perhaps CLI or Winbox, I’ve found webfig to be more consuming on the router and sometimes tedious for tasks causing mistakes like this.
It’d be cool if there was a way that Safe Mode could be configured to be enabled from the very beginnig of a session, and you’d have to turn it off intentionally if you wanted/needed to (call it “cat mode”.)
